Giriş
A simple battery replacement
Requirements
- Philips no.1
- Plastic Picks/prying tools
Battery Safe mode
Before removing internal components, you must place the computer in Battery Safe mode. This mode avoids short-circuits or system malfunction by removing power from internal components.
To place the computer in Battery Safe mode, follow these steps:
With the computer turned off and AC adapter connected, press the following key and button combination:
Windows key + Backspace key + Power button.
After the computer powers off, disconnect the AC adapter.
To disengage Battery Safe mode, plug in the AC adapter and press the power button.
Neye ihtiyacın var
7 P1 screws, green are removed the rest are retained
Start with the hinge useing picks to slip inbetween the plastic and a spudger to pry apart
The Ethernet jack is secured inside, do not try to remove
Remove the two P1 Screws and lift the battery out. being carefull to apply even presure across the battery
Bir başkası bu kılavuzu tamamladı.
