Ana içeriğe geç
Giriş
If the keys on your keyboard are unresponsive or damaged, remove the keyboard for cleaning or replacement.
Parçalar
Hiçbir parça belirtilmedi.
  1. Flip the 4520s upside-down with the front toward you. Push the two latches below the battery inwards at the same time.
    • Flip the 4520s upside-down with the front toward you.
    • Push the two latches below the battery inwards at the same time.
  2. Remove the battery by holding the latches and sliding the battery away from you.
    • Remove the battery by holding the latches and sliding the battery away from you.
  3. Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located. Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
    • Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
  4. Android Tamir Setleri
    Yeni bir ekran veya pil, bir tamir kiti kadar yakınında.
    Hemen Alışveriş Yapın
  5. Flip the 4520s over and rotate it so the back is facing you. Use a metal spudger to peel off two rubber caps located on either side of the battery port.
    • Flip the 4520s over and rotate it so the back is facing you.
    • Use a metal spudger to peel off two rubber caps located on either side of the battery port.
  6. Use a Phillips #1 screwdriver to remove the 3mm screws behind the caps.
    • Use a Phillips #1 screwdriver to remove the 3mm screws behind the caps.
  7. Rotate the 4520s and then open it with the screen facing you. The switch cover is located above the keyboard.  Push the switch cover away from you until it comes loose from the 4520s. Lift the switch cover away from the 4520s and set it aside.
    • Rotate the 4520s and then open it with the screen facing you.
    • The switch cover is located above the keyboard. Push the switch cover away from you until it comes loose from the 4520s.
    • Lift the switch cover away from the 4520s and set it aside.
  8. Use a Phillips #1 screwdriver to remove the two 7mm screws located on either side of the keyboard panel. Use a Phillips #1 screwdriver to remove the two 7mm screws located on either side of the keyboard panel.
    • Use a Phillips #1 screwdriver to remove the two 7mm screws located on either side of the keyboard panel.
  9. Slide the keyboard panel away from you to free it from the 4520s.
    • Slide the keyboard panel away from you to free it from the 4520s.
    • Do not yank the keyboard panel away from the 4520s. This may damage the cable.
    Does keyboard slide away or to right/left? thought it was to the right.
    Heidi Bell - Yanıt
    Keyboard goes directly away
    Robert Spencer Harrison -
  10. Gently raise up the keyboard and flip it over to reveal a ribbon cable. Release the ribbon cable by carefully lifting the black tab upwards, one side at a time.
    • Gently raise up the keyboard and flip it over to reveal a ribbon cable.
    • Release the ribbon cable by carefully lifting the black tab upwards, one side at a time.
    • Remove the cable and lift the keyboard panel up. Set it aside.
    • When reassembling, feed the ribbon cable into the port. Press down on the tab to pinch the cable in place.
Sonuç
To reassemble your device, follow these steps in reverse order.
6 farklı kişi bu kılavuzu tamamladı.
947 İtibar
4 adet Kılavuz yazıldı
Takım
UC Davis, Team 1-3, Oliver Fall 2016 UC Davis, Team 1-3, Oliver Fall 2016 üyesi
UCD-OLIVER-F16S1G3
5 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
hp probook 4520s disassembly
https://youtu.be/8749zmz0lls
mohamed - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 55
Her zaman: 2,911
