Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
If the keys on your keyboard are unresponsive or damaged, remove the keyboard for cleaning or replacement.
Neye ihtiyacın var
Flip the 4520s upside-down with the front toward you.
Push the two latches below the battery inwards at the same time.
Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
Use a Phillips #1 screwdriver to remove the two 7mm screws located on either side of the keyboard panel.
To reassemble your device, follow these steps in reverse order.
7 farklı kişi bu kılavuzu tamamladı.
