Giriş
If your 4520s can't read CD's or DVD's, you might have a faulty optical drive. Replacing the optical drive may solve the problem.
Neye ihtiyacın var
Flip the 4520s upside-down with the front toward you.
Push the two latches below the battery inwards at the same time.
Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
Use a Phillips #1 screwdriver to remove the two 7mm screws located on either side of the keyboard panel.
The housing for the optical drive is on the right of the device.
Remove the 5mm screw on the left side of the metal plate with a Phillips (PH1) head screwdriver.
