Ana içeriğe geç
HP ProBook 4520s Screen Replacement
Neye ihtiyacın var
  1. HP ProBook 4520s Screen Replacement, Battery: adım 1, 2 resimden 1. HP ProBook 4520s Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the 4520s upside-down with the front toward you.
    • Push the two latches below the battery inwards at the same time.
    FixBot'a Sor
    Yorum Ekle
  2. HP ProBook 4520s Screen Replacement: adım 2, 1 resimden 1.
    • Remove the battery by holding the latches and sliding the battery away from you.
    FixBot'a Sor
    Yorum Ekle
  3. HP ProBook 4520s Screen Replacement, Switch Cover: adım 3, 2 resimden 1. HP ProBook 4520s Screen Replacement, Switch Cover: adım 3, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
    FixBot'a Sor
    Yorum Ekle
  4. HP ProBook 4520s Screen Replacement: adım 4, 2 resimden 1. HP ProBook 4520s Screen Replacement: adım 4, 2 resimden 2.
    • Flip the 4520s over and rotate it so the back is facing you.
    • Use a metal spudger to peel off two rubber caps located on either side of the battery port.
    FixBot'a Sor
    Yorum Ekle
  5. HP ProBook 4520s Screen Replacement: adım 5, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the 3mm screws behind the caps.
    FixBot'a Sor
    Yorum Ekle
  6. HP ProBook 4520s Screen Replacement: adım 6, 3 resimden 1. HP ProBook 4520s Screen Replacement: adım 6, 3 resimden 2. HP ProBook 4520s Screen Replacement: adım 6, 3 resimden 3.
    • Rotate the 4520s and then open it with the screen facing you.
    • The switch cover is located above the keyboard. Push the switch cover away from you until it comes loose from the 4520s.
    • Lift the switch cover away from the 4520s and set it aside.
    FixBot'a Sor
    Yorum Ekle
  7. HP ProBook 4520s Screen Replacement, Screen: adım 7, 2 resimden 1. HP ProBook 4520s Screen Replacement, Screen: adım 7, 2 resimden 2.
    • Use a metal spudger to remove four rubber caps at the bottom of the screen border.
    FixBot'a Sor
    Yorum Ekle
  8. HP ProBook 4520s Screen Replacement: adım 8, 2 resimden 1. HP ProBook 4520s Screen Replacement: adım 8, 2 resimden 2.
    • Use a Torx (T9) head screwdriver to remove the four 5mm screws beneath the rubber caps.
    FixBot'a Sor
    Yorum Ekle
  9. HP ProBook 4520s Screen Replacement: adım 9, 3 resimden 1. HP ProBook 4520s Screen Replacement: adım 9, 3 resimden 2. HP ProBook 4520s Screen Replacement: adım 9, 3 resimden 3.
    • Pry open the tabs behind the border of the screen using a metal spudger.
    • Set the border of the screen aside.
    FixBot'a Sor
    Yorum Ekle
  10. HP ProBook 4520s Screen Replacement: adım 10, 2 resimden 1. HP ProBook 4520s Screen Replacement: adım 10, 2 resimden 2.
    • Use a Torx (T9) head screwdriver to remove two 5mm screws above the screen, and two more screws below it.
    • The bottom set of screws is installed on the innermost screw holes.
    FixBot'a Sor
    Yorum Ekle
  11. HP ProBook 4520s Screen Replacement: adım 11, 1 resimden 1.
    • Above the screen is a bronze port with a cable connected to it. Disconnect the cable using a metal spudger or your finger.
    FixBot'a Sor
    Yorum Ekle
  12. HP ProBook 4520s Screen Replacement: adım 12, 1 resimden 1.
    • Gently push the back cover away.
    FixBot'a Sor
    Yorum Ekle
  13. HP ProBook 4520s Screen Replacement: adım 13, 3 resimden 1. HP ProBook 4520s Screen Replacement: adım 13, 3 resimden 2. HP ProBook 4520s Screen Replacement: adım 13, 3 resimden 3.
    • Use a Phillips (PH1) head screwdriver to remove eight 2mm screws from the screen. Four of the screws will be on the left side and four will be on the right.
    • Place the screen face down.
    FixBot'a Sor
    Yorum Ekle
  14. HP ProBook 4520s Screen Replacement: adım 14, 3 resimden 1. HP ProBook 4520s Screen Replacement: adım 14, 3 resimden 2. HP ProBook 4520s Screen Replacement: adım 14, 3 resimden 3.
    • Peel the ribbon cable away from the screen.
    FixBot'a Sor
    Yorum Ekle
  15. HP ProBook 4520s Screen Replacement: adım 15, 2 resimden 1. HP ProBook 4520s Screen Replacement: adım 15, 2 resimden 2.
    • To open the clamp for the ribbon cable, use a spudger to pry up the metal bar securing it to the screen.
    • Disconnect the cable after freeing it from the metal bar
    FixBot'a Sor
    Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Robert Spencer Harrison
1.422 İtibar
4 adet Kılavuz yazıldı
Ekip
UC Davis, Team 1-3, Oliver Fall 2016 UC Davis, Team 1-3, Oliver Fall 2016 üyesi
UCD-OLIVER-F16S1G3
5 Üyeler
8 adet Kılavuz yazıldı
2Kılavuz Yorumları
I need back cover hp i5 probook 4520s
amir86216 - Yanıt Paylaş
I need speakers hp probook 4520s i5
Osagie Rmd - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 60
Her zaman: 6,987
