Ana içeriğe geç
HP ProBook 4520s Switch Cover Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. HP ProBook 4520s Switch Cover Replacement, Battery: adım 1, 2 resimden 1. HP ProBook 4520s Switch Cover Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the 4520s upside-down with the front toward you.
    • Push the two latches below the battery inwards at the same time.
  2. HP ProBook 4520s Switch Cover Replacement: adım 2, 1 resimden 1.
    • Remove the battery by holding the latches and sliding the battery away from you.
  3. HP ProBook 4520s Switch Cover Replacement, Switch Cover: adım 3, 2 resimden 1. HP ProBook 4520s Switch Cover Replacement, Switch Cover: adım 3, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
  4. HP ProBook 4520s Switch Cover Replacement: adım 4, 2 resimden 1. HP ProBook 4520s Switch Cover Replacement: adım 4, 2 resimden 2.
    • Flip the 4520s over and rotate it so the back is facing you.
    • Use a metal spudger to peel off two rubber caps located on either side of the battery port.
  5. HP ProBook 4520s Switch Cover Replacement: adım 5, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the 3mm screws behind the caps.
  6. HP ProBook 4520s Switch Cover Replacement: adım 6, 3 resimden 1. HP ProBook 4520s Switch Cover Replacement: adım 6, 3 resimden 2. HP ProBook 4520s Switch Cover Replacement: adım 6, 3 resimden 3.
    • Rotate the 4520s and then open it with the screen facing you.
    • The switch cover is located above the keyboard. Push the switch cover away from you until it comes loose from the 4520s.
    • Lift the switch cover away from the 4520s and set it aside.
Sonuç
Robert Spencer Harrison
1.341 İtibar
4 adet Kılavuz yazıldı
Ekip
UC Davis, Team 1-3, Oliver Fall 2016 UC Davis, Team 1-3, Oliver Fall 2016 üyesi
UCD-OLIVER-F16S1G3
5 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 178
