Giriş
This guide will teach you how to properly remove and replace the HDD in the ProBook 4530s.
Neye ihtiyacın var
Press inward on the two switches.
The battery should pop out slightly.
Remove the battery.
Press inward on both switches while pushing the center panel away from you. It should slide slightly backwards.
Release the switches.
Slide the panel the rest of the way out.
Unscrew the four screws located on the edges of the base.
Lift enough on the right side of the HDD to make it over the plastic paneling.
Pull outward.
Remove the adhesive from the protective covering over the HDD.
Remove the four screws around the edges of the metal base.
Pull out the HDD from the base.
8 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Clear and easy instructions. It’s nice to encounter a computer with such easy access to the internals.
You have saved me time and money from going to my engineer to help me out. Thank you.
