Ana içeriğe geç
HP ProBook 4530s RAM Replacement
    1. HP ProBook 4530s RAM Replacement, Introduction: adım 1, 1 resimden 1.
      • Start by flipping the laptop over onto its back.
      FixBot'a Sor
      Yorum Ekle
    2. HP ProBook 4530s RAM Replacement, Battery Removal: adım 2, 1 resimden 1.
      • Press in on both sides, the switches will release the battery.
      • The battery will pop out slightly, allowing you to pull it out.
      FixBot'a Sor
      Yorum Ekle
    3. HP ProBook 4530s RAM Replacement, Bottom Panel Removal: adım 3, 1 resimden 1.
      • Press in on both switches, while pushing onto the plastic panel behind them.
      • The panel should slide out.
      FixBot'a Sor
      Yorum Ekle
    4. HP ProBook 4530s RAM Replacement, Locate and Disassemble: adım 4, 3 resimden 1. HP ProBook 4530s RAM Replacement, Locate and Disassemble: adım 4, 3 resimden 2. HP ProBook 4530s RAM Replacement, Locate and Disassemble: adım 4, 3 resimden 3.
      • Locate the RAM slightly to the center-left.
      • Press outward on the metal retention arms for the RAM.
      • The RAM should pop upward slightly.
      FixBot'a Sor
      Yorum Ekle
    5. HP ProBook 4530s RAM Replacement, RAM Removal: adım 5, 1 resimden 1.
      • Grab the RAM gently and remove at a 45 Degree angle.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Drew Canada
1.490 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 20
Son 30 gün: 47
Her zaman: 3,774
