Giriş
Removing the keyboard will require removing the bottom door before turning it over to remove the keyboard. Be wary of any loose components when the laptop is turned right side up.
Neye ihtiyacın var
Slide the two release latches on either side of the battery.
Gently tilt the battery upward and remove it from its socket.
Turn the computer so the bottom is facing towards you.
Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
15 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Precise and clear guide. Great Work!!!
