Ana içeriğe geç
HP ProBook 4540s Keyboard Replacement
Neye ihtiyacın var
  1. HP ProBook 4540s Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the computer is shut off and the power cord is unplugged from the AC outlet.
    • Slide the two release latches on either side of the battery.
    • Gently tilt the battery upward and remove it from its socket.
  2. HP ProBook 4540s Keyboard Replacement, Bottom Door: adım 2, 1 resimden 1.
    • Turn the computer so the bottom is facing towards you.
    • Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
    • The security screw is an optional feature and isn't required to hold the backing if there is not one screwed in place.
    • Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
  3. HP ProBook 4540s Keyboard Replacement, Keyboard: adım 3, 1 resimden 1.
    • Remove four 6.0 mm Phillips PM2.5x6.0 screws.
  4. HP ProBook 4540s Keyboard Replacement: adım 4, 1 resimden 1.
    • Turn the computer over and position it right-side up in order and open the computer as far as possible.
  5. HP ProBook 4540s Keyboard Replacement: adım 5, 1 resimden 1.
    • Move the keyboard in a downward fashion towards the palm rest.
  6. HP ProBook 4540s Keyboard Replacement: adım 6, 1 resimden 1.
    • Lift the top of the keyboard at an angle and then gently pull it up and away from the palm rest.
    • Only pull the keyboard up enough to release it. The cable beneath the keyboard will still be attached to the system board.
  7. HP ProBook 4540s Keyboard Replacement: adım 7, 1 resimden 1.
    • Disconnect the keyboard cable by lifting the latch at the center of the system board.
    • Completely remove the keyboard.
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Amber Schindler
1.027 İtibar
6 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 1-5, Rose Fall 2016 UW Tacoma, Team 1-5, Rose Fall 2016 üyesi
UWT-ROSE-F16S1G5
4 Üyeler
2 Yorum
Precise and clear guide. Great Work!!!
Mario Mutale - Yanıt
Easy to follow and a great help to get the job done. Thanks
d1211109 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 27
Her zaman: 7,173
