Ana içeriğe geç
HP ProBook 4540s Optical Drive Replacement
Neye ihtiyacın var
  1. HP ProBook 4540s Optical Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the computer is shut off and the power cord is unplugged from the AC outlet.
    • Slide the two release latches on either side of the battery.
    • Gently tilt the battery upward and remove it from its socket.
  2. HP ProBook 4540s Optical Drive Replacement, Bottom Door: adım 2, 1 resimden 1.
    • Turn the computer so the bottom is facing towards you.
    • Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
    • The security screw is an optional feature and isn't required to hold the backing if there is not one screwed in place.
    • Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
  3. HP ProBook 4540s Optical Drive Replacement, Optical/CD Drive: adım 3, 2 resimden 1. HP ProBook 4540s Optical Drive Replacement, Optical/CD Drive: adım 3, 2 resimden 2.
    • Remove one 6.0 mm Phillips PM2.5x6.0 screw that is securing the optical drive.
  4. HP ProBook 4540s Optical Drive Replacement: adım 4, 2 resimden 1. HP ProBook 4540s Optical Drive Replacement: adım 4, 2 resimden 2.
    • Press the optical drive tab to release the drive component.
    • Gently pull and remove the component from the computer.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Amber Schindler
1.027 İtibar
6 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 1-5, Rose Fall 2016 UW Tacoma, Team 1-5, Rose Fall 2016 üyesi
UWT-ROSE-F16S1G5
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 17
Her zaman: 2,388
