Ana içeriğe geç
HP ProBook 4540s WLAN Module Replacement
Neye ihtiyacın var
    1. HP ProBook 4540s WLAN Module Replacement, Battery: adım 1, 1 resimden 1.
      • Make sure the computer is shut off and the power cord is unplugged from the AC outlet.
      • Slide the two release latches on either side of the battery.
      • Gently tilt the battery upward and remove it from its socket.
      FixBot'a Sor
      Yorum Ekle
    1. HP ProBook 4540s WLAN Module Replacement, Bottom Door: adım 2, 1 resimden 1.
      • Turn the computer so the bottom is facing towards you.
      • Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
      • The security screw is an optional feature and isn't required to hold the backing if there is not one screwed in place.
      • Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
      FixBot'a Sor
      Yorum Ekle
    1. HP ProBook 4540s WLAN Module Replacement, WLAN Module: adım 3, 2 resimden 1. HP ProBook 4540s WLAN Module Replacement, WLAN Module: adım 3, 2 resimden 2.
      • Disconnect the antenna cables from their terminals in the WLAN module.
      • One cable is attached to the Auxiliary ("Aux") terminal, represented with a blue wire. The other cable is connected to the Main terminal which is usually represented with a red wire. These wires can be seen in little windows beside the component.
      FixBot'a Sor
      Yorum Ekle
    2. HP ProBook 4540s WLAN Module Replacement: adım 4, 2 resimden 1. HP ProBook 4540s WLAN Module Replacement: adım 4, 2 resimden 2.
      • Unscrew two 3.0 mm Phillips PM2.0x3.0 screw securing the module to the computer.
      • The edge of the module that is opposite of the slot is risen away from the computer.
      • Gently lift and remove the module.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Amber Schindler
1.087 İtibar
6 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 1-5, Rose Fall 2016 UW Tacoma, Team 1-5, Rose Fall 2016 üyesi
UWT-ROSE-F16S1G5
4 Üyeler
30 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 38
Her zaman: 2,499
