Ana içeriğe geç
HP ProBook 455 G1 DVD/CD Drive Replacement
Neye ihtiyacın var
  1. HP ProBook 455 G1 DVD/CD Drive  Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the computer upside down on a flat side, so that you are seeing the underside of the laptop.
    • Before removing the battery, make sure that the computer is turned off and that the power cord is not plugged into the computer.
  2. HP ProBook 455 G1 DVD/CD Drive  Replacement: adım 2, 1 resimden 1.
    • Slide the two battery release latches towards the center of the laptop to release the battery.
  3. HP ProBook 455 G1 DVD/CD Drive  Replacement: adım 3, 2 resimden 1. HP ProBook 455 G1 DVD/CD Drive  Replacement: adım 3, 2 resimden 2.
    • Tilt the battery upward.
    • Remove it from the laptop.
  4. HP ProBook 455 G1 DVD/CD Drive  Replacement, Service Panel: adım 4, 1 resimden 1.
    • Slide the two release latches that were mentioned in the battery removal process to release the service panel.
  5. HP ProBook 455 G1 DVD/CD Drive  Replacement: adım 5, 2 resimden 1. HP ProBook 455 G1 DVD/CD Drive  Replacement: adım 5, 2 resimden 2.
    • Slide the service panel toward you using your thumbs.
    • Lift it to remove the panel and reveal inner components of the computer.
  6. HP ProBook 455 G1 DVD/CD Drive  Replacement, DVD/CD Drive: adım 6, 2 resimden 1. HP ProBook 455 G1 DVD/CD Drive  Replacement, DVD/CD Drive: adım 6, 2 resimden 2.
    • Using a Phillips P0 Screwdriver, remove the 6 millimeter screw that secures the DVD/CD drive to the computer.
    • It will be located in the upper left section of the computer, housed in a small square hole in the computer frame.
    • The Phillips head screwdriver is the screwdriver with a "+" shaped tip. P0 refers to the name/size of this particular Phillips head screwdriver.
  7. HP ProBook 455 G1 DVD/CD Drive  Replacement: adım 7, 1 resimden 1.
    • Using the screwdriver, gently push the silver tab that the screw secured to the left to release the DVD/CD drive from the computer.
  8. HP ProBook 455 G1 DVD/CD Drive  Replacement: adım 8, 1 resimden 1.
    • The DVD/CD drive will be extended from the side of the laptop. Slowly remove it from the computer.
Sonuç
Jennifer Sexton
649 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team S5-G1, Williams Spring 2018 Baylor, Team S5-G1, Williams Spring 2018 üyesi
BU-WILLIAMS-S18S5G1
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 914
