Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Your computer's hard drive may become damaged after prolonged use or age. One of the ways you can fix this is by replacing the drive itself. This guide is designed to help you safely and properly remove your computer’s hard drive, no matter what the reason may be.
Neye ihtiyacın var
Turn the computer upside down on a flat side, so that you are seeing the underside of the laptop.
Slide the two release latches that were mentioned in the battery removal process to release the service panel.
Using a Phillips #0 Screwdriver, remove the four Phillips 3 mm screws that secure the hard drive into the computer.
7 farklı kişi bu kılavuzu tamamladı.
