Ana içeriğe geç
HP ProBook 640 G5 Battery Replacement
Neye ihtiyacın var
  1. HP ProBook 640 G5 Battery Replacement, Back Cover: adım 1, 1 resimden 1.
    • Always make sure the HP ProBook 640 G5 is completely powered off and unplugged before beginning this repair. Attempting to open the laptop while it has power may cause electrical damage or personal injury.
    • Shut down the HP ProBook 640 G5 completely.
    • Disconnect the power adapter and all connected peripherals.
    • Press and hold the power button for 5 seconds to discharge remaining electricity.
    FixBot'a Sor
    Yorum Ekle
  2. HP ProBook 640 G5 Battery Replacement: adım 2, 1 resimden 1.
    • Flip the laptop over so the bottom is facing up.
    • Loosen eight silver 6mm screws using a Phillips #0 screwdriver.
    • These screws are captive, so they will loosen but remain attached to the cover.
    • Remove two black 6mm screws using a TR7 Torx screwdriver.
    • Insert a plastic opening tool into the seam and gently pry around the edges.
    • Lift the bottom cover away from the laptop.
    FixBot'a Sor
    Yorum Ekle
  3. HP ProBook 640 G5 Battery Replacement, Battery: adım 3, 3 resimden 1. HP ProBook 640 G5 Battery Replacement, Battery: adım 3, 3 resimden 2. HP ProBook 640 G5 Battery Replacement, Battery: adım 3, 3 resimden 3.
    • Remove six 6mm and two 2mm screws using a Phillips #0 screwdriver.
    • The screws on the battery can be hard to remove as they need to be unscrewed, stood up, then unscrewed fully. You can use the tweezers to pull up the screw in place. You'll know it's in the proper place when you go to unscrew it and it comes out smoothly.
    FixBot'a Sor
    Yorum Ekle
  4. HP ProBook 640 G5 Battery Replacement: adım 4, 2 resimden 1. HP ProBook 640 G5 Battery Replacement: adım 4, 2 resimden 2.
    • Lift the battery near the lower end and pull it out of the slot on the top.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Jack Cowan
85 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 15
Son 30 gün: 55
Her zaman: 124
