Ana içeriğe geç
HP ProBook 645 Keyboard Replacement
Neye ihtiyacın var
  1. HP ProBook 645 Keyboard Replacement, Remove 2 screws: adım 1, 1 resimden 1.
    • Remove the two screws at the two indicated locations with the phillips head screw driver.
    FixBot'a Sor
    Yorum Ekle
  2. HP ProBook 645 Keyboard Replacement, Flip unit over and open lid.: adım 2, 1 resimden 1.
    • Take a spudger tool and pry the keyboard down toward the mouse pad and up toward you. After you raise the keyboard there are tabs at the bottom. Pull the keyboard away from you, and it will dislodge.
    FixBot'a Sor
    Yorum Ekle
  3. HP ProBook 645 Keyboard Replacement, Ribbon Removal: adım 3, 1 resimden 1.
    • 1. Remove ribbon by flipping the black tab up and gently pulling on the ribbon.
    • 2. This ribbon has no tab, gently pull on until it comes loose. To reinsert. Line it up carefully as not to damage the ribbon, and push gently.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Doug
191 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 38
Her zaman: 4,907
