Giriş
The HP ProBook 650 G2 makes it fairly easy to replace the battery quickly.
Neye ihtiyacın var
Start at the back near the hinge with a pry tool
Work your way around to the front using enough pressure to release the plastic clips
Once you get near the opposite corner it should release to a point where you can use your hand to pull it open
There are 7 captive screws (on the original HP battery) around the edge of the battery that use a PH1 bit
Once the screws are removed you can use the tab nearest the front center of the laptop to lift the battery up and out
If your new battery did not come with the captive screws you can unscrew them from the old battery by applying pressure under the screw while unscrewing them so you can transfer them to the new battery
