Ana içeriğe geç
HP ProBook 650 G2 Battery Replacement
Neye ihtiyacın var
  1. HP ProBook 650 G2 Battery Replacement, Remove the case screws: adım 1, 1 resimden 1.
    • There are 8 case screws that all use a PH1 bit
  2. HP ProBook 650 G2 Battery Replacement, Pry open the case: adım 2, 3 resimden 1. HP ProBook 650 G2 Battery Replacement, Pry open the case: adım 2, 3 resimden 2. HP ProBook 650 G2 Battery Replacement, Pry open the case: adım 2, 3 resimden 3.
    • Start at the back near the hinge with a pry tool
    • Work your way around to the front using enough pressure to release the plastic clips
    • Once you get near the opposite corner it should release to a point where you can use your hand to pull it open
  3. HP ProBook 650 G2 Battery Replacement, Remove the battery: adım 3, 2 resimden 1. HP ProBook 650 G2 Battery Replacement, Remove the battery: adım 3, 2 resimden 2.
    • There are 7 captive screws (on the original HP battery) around the edge of the battery that use a PH1 bit
    • Once the screws are removed you can use the tab nearest the front center of the laptop to lift the battery up and out
  4. HP ProBook 650 G2 Battery Replacement, (Optional) Remove captive screws: adım 4, 1 resimden 1.
    • If your new battery did not come with the captive screws you can unscrew them from the old battery by applying pressure under the screw while unscrewing them so you can transfer them to the new battery
Sonuç
The Bearded IT Guy
109 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 37
Her zaman: 303
