Giriş
If your HP Probook x360 11 G5 EE laptop does not charge unless the adapter is positioned in a specific position, the charging port may need to be replaced. The charging port is important because it charges the battery to supply the power to your laptop.
Neye ihtiyacın var
Remove the 4.1 mm screws with a T5 Torx screwdriver.
Remove the 4.1 mm screws using a JIS #0 screwdriver.
Remove the single 3 mm screw from the charging port using a T5 Torx screwdriver.
Bir başkası bu kılavuzu tamamladı.
2Kılavuz Yorumları
Hi!! I have the same model of notebook with 64 giga emmc. Is it possible installing an ssd or an hdd?
I followed each and every step, and realised a little too late that my laptop is a HP ProBook x360 11 G1 -and not a G5. The G1 requires the ability to de-solder the built in charging port.
On step 6, I noticed there were 6 screws holding the battery in, not 4.
Then on step 9, I noticed that the charging port is actually soldered to the motherboard and there is no visible cable attaching it to the board which can be unhooked.
