Ana içeriğe geç
HP ProBook x360 11 G5 EE Charging Port Replacement
Neye ihtiyacın var
  1. HP ProBook x360 11 G5 EE Charging Port Replacement, Keyboard Assembly: adım 1, 3 resimden 1. HP ProBook x360 11 G5 EE Charging Port Replacement, Keyboard Assembly: adım 1, 3 resimden 2. HP ProBook x360 11 G5 EE Charging Port Replacement, Keyboard Assembly: adım 1, 3 resimden 3.
    • Remove the 4.1 mm screws with a T5 Torx screwdriver.
    • Remove the 4.1 mm screws using a JIS #0 screwdriver.
  2. HP ProBook x360 11 G5 EE Charging Port Replacement: adım 2, 1 resimden 1.
    • Use an opening pick to pry the corners of the keyboard deck.
  3. HP ProBook x360 11 G5 EE Charging Port Replacement: adım 3, 3 resimden 1. HP ProBook x360 11 G5 EE Charging Port Replacement: adım 3, 3 resimden 2. HP ProBook x360 11 G5 EE Charging Port Replacement: adım 3, 3 resimden 3.
    • Use an opening pick or opening tool to pry around the sides of the keyboard assembly.
  4. HP ProBook x360 11 G5 EE Charging Port Replacement: adım 4, 3 resimden 1. HP ProBook x360 11 G5 EE Charging Port Replacement: adım 4, 3 resimden 2. HP ProBook x360 11 G5 EE Charging Port Replacement: adım 4, 3 resimden 3.
    • Lift the keyboard assembly to expose two ribbon cables.
    • Lift the two plastic tabs that hold the cables in place on the motherboard
    • Slide the ribbon cables out of each connector.
  5. HP ProBook x360 11 G5 EE Charging Port Replacement: adım 5, 2 resimden 1. HP ProBook x360 11 G5 EE Charging Port Replacement: adım 5, 2 resimden 2.
    • Remove the keyboard assembly from the rest of the computer.
  6. HP ProBook x360 11 G5 EE Charging Port Replacement, Battery: adım 6, 2 resimden 1. HP ProBook x360 11 G5 EE Charging Port Replacement, Battery: adım 6, 2 resimden 2.
    • Remove the four 3 mm screws from the battery with the JIS #0 screwdriver.
  7. HP ProBook x360 11 G5 EE Charging Port Replacement: adım 7, 3 resimden 1. HP ProBook x360 11 G5 EE Charging Port Replacement: adım 7, 3 resimden 2. HP ProBook x360 11 G5 EE Charging Port Replacement: adım 7, 3 resimden 3.
    • Pry the battery up from the laptop using an opening pick.
    • Lift the battery out of its place.
  8. HP ProBook x360 11 G5 EE Charging Port Replacement, Charging Port: adım 8, 2 resimden 1. HP ProBook x360 11 G5 EE Charging Port Replacement, Charging Port: adım 8, 2 resimden 2.
    • Remove the single 3 mm screw from the charging port using a T5 Torx screwdriver.
  9. HP ProBook x360 11 G5 EE Charging Port Replacement: adım 9, 3 resimden 1. HP ProBook x360 11 G5 EE Charging Port Replacement: adım 9, 3 resimden 2. HP ProBook x360 11 G5 EE Charging Port Replacement: adım 9, 3 resimden 3.
    • Disconnect the charging port wire from the motherboard.
    • Remove the charging port from your device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Michelle Pina
506 İtibar
4 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-4, Pee Fall 2021 Gateway, Team 1-4, Pee Fall 2021 üyesi
GCC-PEE-F21S1G4
5 Üyeler
5 adet Kılavuz yazıldı
2Kılavuz Yorumları
Hi!! I have the same model of notebook with 64 giga emmc. Is it possible installing an ssd or an hdd?
Riccardo Insolera - Yanıt
I followed each and every step, and realised a little too late that my laptop is a HP ProBook x360 11 G1 -and not a G5. The G1 requires the ability to de-solder the built in charging port.
On step 6, I noticed there were 6 screws holding the battery in, not 4.
Then on step 9, I noticed that the charging port is actually soldered to the motherboard and there is no visible cable attaching it to the board which can be unhooked.
Sam T - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 63
Her zaman: 1,209
