Ana içeriğe geç
HP ProBook x360 11 G5 EE Speakers Replacement
Neye ihtiyacın var
  1. HP ProBook x360 11 G5 EE Speakers Replacement, Keyboard Assembly: adım 1, 3 resimden 1. HP ProBook x360 11 G5 EE Speakers Replacement, Keyboard Assembly: adım 1, 3 resimden 2. HP ProBook x360 11 G5 EE Speakers Replacement, Keyboard Assembly: adım 1, 3 resimden 3.
    • Remove the 4.1 mm screws with a T5 Torx screwdriver.
    • Remove the 4.1 mm screws using a JIS #0 screwdriver.
  2. HP ProBook x360 11 G5 EE Speakers Replacement: adım 2, 1 resimden 1.
    • Use an opening pick to pry the corners of the keyboard deck.
  3. HP ProBook x360 11 G5 EE Speakers Replacement: adım 3, 3 resimden 1. HP ProBook x360 11 G5 EE Speakers Replacement: adım 3, 3 resimden 2. HP ProBook x360 11 G5 EE Speakers Replacement: adım 3, 3 resimden 3.
    • Use an opening pick or opening tool to pry around the sides of the keyboard assembly.
  4. HP ProBook x360 11 G5 EE Speakers Replacement: adım 4, 3 resimden 1. HP ProBook x360 11 G5 EE Speakers Replacement: adım 4, 3 resimden 2. HP ProBook x360 11 G5 EE Speakers Replacement: adım 4, 3 resimden 3.
    • Lift the keyboard assembly to expose two ribbon cables.
    • Lift the two plastic tabs that hold the cables in place on the motherboard
    • Slide the ribbon cables out of each connector.
  5. HP ProBook x360 11 G5 EE Speakers Replacement: adım 5, 2 resimden 1. HP ProBook x360 11 G5 EE Speakers Replacement: adım 5, 2 resimden 2.
    • Remove the keyboard assembly from the rest of the computer.
  6. HP ProBook x360 11 G5 EE Speakers Replacement, Battery: adım 6, 2 resimden 1. HP ProBook x360 11 G5 EE Speakers Replacement, Battery: adım 6, 2 resimden 2.
    • Remove the four 3 mm screws from the battery with the JIS #0 screwdriver.
  7. HP ProBook x360 11 G5 EE Speakers Replacement: adım 7, 3 resimden 1. HP ProBook x360 11 G5 EE Speakers Replacement: adım 7, 3 resimden 2. HP ProBook x360 11 G5 EE Speakers Replacement: adım 7, 3 resimden 3.
    • Pry the battery up from the laptop using an opening pick.
    • Lift the battery out of its place.
  8. HP ProBook x360 11 G5 EE Speakers Replacement, Speakers: adım 8, 2 resimden 1. HP ProBook x360 11 G5 EE Speakers Replacement, Speakers: adım 8, 2 resimden 2.
    • Remove the four 5 mm screws holding the speakers in place using a JIS #0 screwdriver.
  9. HP ProBook x360 11 G5 EE Speakers Replacement: adım 9, 2 resimden 1. HP ProBook x360 11 G5 EE Speakers Replacement: adım 9, 2 resimden 2.
    • Disconnect the speaker wire from its socket on the motherboard.
  10. HP ProBook x360 11 G5 EE Speakers Replacement: adım 10, 3 resimden 1. HP ProBook x360 11 G5 EE Speakers Replacement: adım 10, 3 resimden 2. HP ProBook x360 11 G5 EE Speakers Replacement: adım 10, 3 resimden 3.
    • Remove the left speaker gently.
    • Remove the cable that connects both speakers together from the notches that hold it in place. Be careful when pulling the wire to avoid damaging it.
    • Remove the right speaker gently.
Sonuç
Michelle Pina
506 İtibar
4 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-4, Pee Fall 2021 Gateway, Team 1-4, Pee Fall 2021 üyesi
GCC-PEE-F21S1G4
5 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 23
Her zaman: 532
