Ana içeriğe geç
HP ProDesk 400 G5 Mini RAM Replacement / Upgrade
Neye ihtiyacın var
  1. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade, RAM: adım 1, 3 resimden 1. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade, RAM: adım 1, 3 resimden 2. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade, RAM: adım 1, 3 resimden 3.
    • Turn the device around the back is facing you.
    • See the large screw in the center back of the PC.
  2. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: adım 2, 3 resimden 1. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: adım 2, 3 resimden 2. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: adım 2, 3 resimden 3.
    • Remove the thumbscrew holding the back panel onto the PC.
  3. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: adım 3, 3 resimden 1. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: adım 3, 3 resimden 2. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: adım 3, 3 resimden 3.
    • Slide the top panel off away from the back of the device.
    • Then, carefully lift it upwards to remove it.
  4. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: adım 4, 3 resimden 1. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: adım 4, 3 resimden 2. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: adım 4, 3 resimden 3.
    • Gently lift the main fan to expose the RAM modules.
  5. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: adım 5, 3 resimden 1. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: adım 5, 3 resimden 2. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: adım 5, 3 resimden 3.
    • Using your fingers, pull the metal arms (located on both sides of the RAM module) slightly away from it, to release it from the slot.
    • The RAM will pop up by a few millimeters.
    • Remove it at an angle and not straight up so you don't damage the socket.
  6. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: adım 6, 3 resimden 1. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: adım 6, 3 resimden 2. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: adım 6, 3 resimden 3.
    • To insert a new RAM stick, line up the indent on the RAM with the indent on the slot, then slide it in.
  7. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: adım 7, 3 resimden 1. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: adım 7, 3 resimden 2. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: adım 7, 3 resimden 3.
    • Push the RAM stick down flat once it's securely attached to the socket.
    • You should hear a tactile click which indicates it was installed correctly.
    • Make sure the arms on both sides go back to their locked position.
  8. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: adım 8, 3 resimden 1. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: adım 8, 3 resimden 2. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: adım 8, 3 resimden 3.
    • After RAM installation, place the fan back on top of the RAM and replace the panel by sliding it into place and tightening it with the thumbscrew.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sam Manshouri
172 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 41
Son 30 gün: 219
Her zaman: 1,599
