Ana içeriğe geç
HP ProOne 600 G1 Fan Replacement
Neye ihtiyacın var
  1. HP ProOne 600 G1 Fan Replacement, Back Removal: adım 1, 2 resimden 1. HP ProOne 600 G1 Fan Replacement, Back Removal: adım 1, 2 resimden 2.
    • Push the unlock tabs on the back of the monitor in and towards each other while sliding the back cover up.
    FixBot'a Sor
    Yorum Ekle
  2. HP ProOne 600 G1 Fan Replacement: adım 2, 2 resimden 1. HP ProOne 600 G1 Fan Replacement: adım 2, 2 resimden 2.
    • Loosen the two 1/2" screws , with the T15 Torx Screwdriver, on each side of the stand. Remove stand.
    FixBot'a Sor
    Yorum Ekle
  3. HP ProOne 600 G1 Fan Replacement: adım 3, 1 resimden 1.
    • Take out the single 3/8" screw, with the T15 Torx Screwdriver, from the middle of the backplate.
    FixBot'a Sor
    Yorum Ekle
  4. HP ProOne 600 G1 Fan Replacement: adım 4, 1 resimden 1.
    • Remove the backplate by pulling it back towards you.
    • Small plastic tabs hold in the backplate, pull these up to remove it.
    FixBot'a Sor
    Yorum Ekle
  5. HP ProOne 600 G1 Fan Replacement, Fan: adım 5, 3 resimden 1. HP ProOne 600 G1 Fan Replacement, Fan: adım 5, 3 resimden 2. HP ProOne 600 G1 Fan Replacement, Fan: adım 5, 3 resimden 3.
    • Remove both 3/8" screws using the T15 Torx Screwdriver from the metal plate, and slide the plate to the left.
    FixBot'a Sor
    Yorum Ekle
  6. HP ProOne 600 G1 Fan Replacement: adım 6, 3 resimden 1. HP ProOne 600 G1 Fan Replacement: adım 6, 3 resimden 2. HP ProOne 600 G1 Fan Replacement: adım 6, 3 resimden 3.
    • Unscrew three surrounding 1/4" screws, with the T15 Torx Screwdriver. Pull out the fan and attached wires.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Victor Chacon
116 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 1-20, Maness Fall 2015 Cal Poly, Team 1-20, Maness Fall 2015 üyesi
CPSU-MANESS-F15S1G20
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 18
Son 30 gün: 54
Her zaman: 2,644
