Ana içeriğe geç
HP ProOne 600 G1 Wi-Fi Adapter Replacement
Neye ihtiyacın var
    1. HP ProOne 600 G1 Wi-Fi Adapter Replacement, Back Removal: adım 1, 2 resimden 1. HP ProOne 600 G1 Wi-Fi Adapter Replacement, Back Removal: adım 1, 2 resimden 2.
      • Push the unlock tabs on the back of the monitor in and towards each other while sliding the back cover up.
      FixBot'a Sor
      Yorum Ekle
    2. HP ProOne 600 G1 Wi-Fi Adapter Replacement: adım 2, 2 resimden 1. HP ProOne 600 G1 Wi-Fi Adapter Replacement: adım 2, 2 resimden 2.
      • Loosen the two 1/2" screws , with the T15 Torx Screwdriver, on each side of the stand. Remove stand.
      FixBot'a Sor
      Yorum Ekle
    3. HP ProOne 600 G1 Wi-Fi Adapter Replacement: adım 3, 1 resimden 1.
      • Take out the single 3/8" screw, with the T15 Torx Screwdriver, from the middle of the backplate.
      FixBot'a Sor
      Yorum Ekle
    4. HP ProOne 600 G1 Wi-Fi Adapter Replacement: adım 4, 1 resimden 1.
      • Remove the backplate by pulling it back towards you.
      • Small plastic tabs hold in the backplate, pull these up to remove it.
      FixBot'a Sor
      Yorum Ekle
    1. HP ProOne 600 G1 Wi-Fi Adapter Replacement, Wi-Fi Adapter: adım 5, 2 resimden 1. HP ProOne 600 G1 Wi-Fi Adapter Replacement, Wi-Fi Adapter: adım 5, 2 resimden 2.
      • Locate the Wi-Fi adapter at the top right corner of where the stand once was.
      • Unscrew the screws using the Philips #1 Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. HP ProOne 600 G1 Wi-Fi Adapter Replacement: adım 6, 1 resimden 1.
      • Remove wire tabs from the left side of the Wi-Fi adapter.
      • Remove the adapter
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Janelle Layman
258 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-20, Maness Fall 2015 Cal Poly, Team 1-20, Maness Fall 2015 üyesi
CPSU-MANESS-F15S1G20
4 Üyeler
42 adet Kılavuz yazıldı
1Rehber Yorum
Muchas gracias, me ha sido de mucha ayuda , cambie la tarjeta por otra y funciono muy bien.
Eliseo - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 56
Her zaman: 5,067
