Giriş
NOTE: HP recommends that the scanner is allowed to cool down for 15 minutes after being disconnected from power before performing this procedure.
NOTE: Clean the outside of the scanner before performing this procedure to prevent contamination of internal parts.
Neye ihtiyacın var
The top has to be lifted straight up at the front and back at the same time.
I found Heavy-Duty Suction Cups (Pair) to work best, but due to the structure of the plastic they quickly loose their grip, so work fast.
Alternative: Lift the top cover in the back as little as possible and use Plastic Cards to work your way to the front until you are able to get a grip of the whole top cover and lift it straight up.
3 farklı kişi bu kılavuzu tamamladı.
