Ana içeriğe geç
HP Slate 7 4601 Charging Port Replacement
Neye ihtiyacın var
  1. HP Slate 7 4601 Charging Port Replacement, Battery: adım 1, 2 resimden 1. HP Slate 7 4601 Charging Port Replacement, Battery: adım 1, 2 resimden 2.
    • Begin your replacement by using a T3 or T4 Torx screwdriver.
    • Remove the two 1.4mm x 3mm Torx Head screws at the top of the device.
  2. HP Slate 7 4601 Charging Port Replacement: adım 2, 2 resimden 1. HP Slate 7 4601 Charging Port Replacement: adım 2, 2 resimden 2.
    • With the pointed end of the spudger, remove the thin metal band.
    • It is easiest to remove the metal band through the headphone opening.
  3. HP Slate 7 4601 Charging Port Replacement: adım 3, 2 resimden 1. HP Slate 7 4601 Charging Port Replacement: adım 3, 2 resimden 2.
    • Using the flat end of the spudger, pry back the rear plastic cover.
    • As you work your way around the edge, several "pop" noises will be made. These noises are caused by the plastic clips coming undone.
  4. HP Slate 7 4601 Charging Port Replacement: adım 4, 1 resimden 1.
    • Remove the rear cover.
  5. HP Slate 7 4601 Charging Port Replacement: adım 5, 1 resimden 1.
    • Locate and remove the yellow tape covering the red and white speaker wires.
  6. HP Slate 7 4601 Charging Port Replacement: adım 6, 2 resimden 1. HP Slate 7 4601 Charging Port Replacement: adım 6, 2 resimden 2.
    • Using the pointed end of the spudger, push both sides of the speaker wire connector out of its base.
    • Push the same amount on both sides of the connector to avoid jamming or twisting its metal pins.
    • Do not yank or pull on the speaker wires, since they are fragile. Only push on the white connector.
  7. HP Slate 7 4601 Charging Port Replacement: adım 7, 1 resimden 1.
    • Gently pull back the foil covering the gold charging port ribbon.
  8. HP Slate 7 4601 Charging Port Replacement: adım 8, 2 resimden 1. HP Slate 7 4601 Charging Port Replacement: adım 8, 2 resimden 2.
    • Using the flat end of the spudger, lift up the black panel covering the charging port connector.
    • Gently slide the charging port ribbon out from its housing.
    • It may be easier to use the pointed end of the spudger than your fingers.
  9. HP Slate 7 4601 Charging Port Replacement: adım 9, 1 resimden 1.
    • Lift gold charging strip away from the battery.
  10. HP Slate 7 4601 Charging Port Replacement: adım 10, 2 resimden 1. HP Slate 7 4601 Charging Port Replacement: adım 10, 2 resimden 2.
    • Push the white battery connector out of its housing using the pointed end of the spudger.
  11. HP Slate 7 4601 Charging Port Replacement: adım 11, 1 resimden 1.
    • Using the #00 Phillips Head screwdriver, remove the 5 screws holding the battery in place.
    • The four 1.75mm x 3mm silver Phillips Head screws circled in red are interchangeable.
    • The black 1.75mm x 4mm Phillips Head screw must go back to the same spot during reassembly.
  12. HP Slate 7 4601 Charging Port Replacement: adım 12, 1 resimden 1.
    • Lift battery out of its place and set aside.
  13. HP Slate 7 4601 Charging Port Replacement, Charging Port: adım 13, 2 resimden 1. HP Slate 7 4601 Charging Port Replacement, Charging Port: adım 13, 2 resimden 2.
    • To free the speaker assembly, you will need a #00 Phillips Head screwdriver.
    • Remove the two 1.75mm x 3mm Phillips Head screws from the speaker assembly.
  14. HP Slate 7 4601 Charging Port Replacement: adım 14, 2 resimden 1. HP Slate 7 4601 Charging Port Replacement: adım 14, 2 resimden 2.
    • Pull back the foil overlapping the charging port to reveal another 1.75mm x 3mm Phillips Head screw.
    • Remove the screw with a #00 Phillips Head screwdriver.
  15. HP Slate 7 4601 Charging Port Replacement: adım 15, 1 resimden 1.
    • Lift the charging port and set it aside.
Sonuç
34 farklı kişi bu kılavuzu tamamladı.
Raj Parekh
535 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 13-30, Maness Spring 2014 Cal Poly, Team 13-30, Maness Spring 2014 üyesi
CPSU-MANESS-S14S13G30
3 Üyeler
8 adet Kılavuz yazıldı
15 Yorum
where do you get the replacement parts for charging port
Scott Winstone - Yanıt
Since HP does not supply the replacement ribbon, or many other parts for that matter, it is easiest to search on eBay and/or Craigslist for the parts needed. I found that the UK version of Amazon and eBay offer the best availability for such parts.
Zachary -
I had to stop at Step 1. The T4 Torx screwdriver is too big.
stevwatsn - Yanıt
My apologies for the incorrect sizing of the Torx driver; please use a T3 sized driver, as it is the next size down from the T4.
Zachary -
do you have a product number for the charger strip?
Courtney - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 18
Her zaman: 47,888
