Ana içeriğe geç
HP Slate 7 4601 Charging Port Replacement
Neye ihtiyacın var
  1. HP Slate 7 4601 Charging Port Replacement, Battery: adım 1, 2 resimden 1. HP Slate 7 4601 Charging Port Replacement, Battery: adım 1, 2 resimden 2.
    • Begin your replacement by using a T3 or T4 Torx screwdriver.
    • Remove the two 1.4mm x 3mm Torx Head screws at the top of the device.
    On the HP 10 Plus 2201 there are no head screws. I used the spudger to 'carefully' separate the case. There are little snaps on the inside of case that will separate with little pressure on spudger.
    RB Richter - Yanıt
    I used these directions to replace HP Plus 10 2201 battery. I bypassed speaker installation.
    RB Richter - Yanıt
  2. HP Slate 7 4601 Charging Port Replacement: adım 2, 2 resimden 1. HP Slate 7 4601 Charging Port Replacement: adım 2, 2 resimden 2.
    • With the pointed end of the spudger, remove the thin metal band.
    • It is easiest to remove the metal band through the headphone opening.
    On HP 10 Plus 2201 there is no metal band. The case simply unsnaps apart.
    RB Richter - Yanıt
  3. HP Slate 7 4601 Charging Port Replacement: adım 3, 2 resimden 1. HP Slate 7 4601 Charging Port Replacement: adım 3, 2 resimden 2.
    • Using the flat end of the spudger, pry back the rear plastic cover.
    • As you work your way around the edge, several "pop" noises will be made. These noises are caused by the plastic clips coming undone.
    This is basically how I opened my HP 10 Plus 2201. "Using the flat end of the spudger, pry back (apart) the rear plastic cover from tablet.
    RB Richter - Yanıt
  4. HP Slate 7 4601 Charging Port Replacement: adım 4, 1 resimden 1.
    • Remove the rear cover.
  5. HP Slate 7 4601 Charging Port Replacement: adım 5, 1 resimden 1.
    • Locate and remove the yellow tape covering the red and white speaker wires.
    The inside of my HP 10 Plus 2210 looks similar but not exactly as this illustration
    RB Richter - Yanıt
    The battery connections weren't the plug in type. The three battery battery wires (red, white, & black) were soldered into place,
    RB Richter - Yanıt
  6. HP Slate 7 4601 Charging Port Replacement: adım 6, 2 resimden 1. HP Slate 7 4601 Charging Port Replacement: adım 6, 2 resimden 2.
    • Using the pointed end of the spudger, push both sides of the speaker wire connector out of its base.
    • Push the same amount on both sides of the connector to avoid jamming or twisting its metal pins.
    • Do not yank or pull on the speaker wires, since they are fragile. Only push on the white connector.
    Do not pull on wires. Never force anything.
    RB Richter - Yanıt
    note the route of the speaker cables round the battery
    Alan Boddey - Yanıt
  7. HP Slate 7 4601 Charging Port Replacement: adım 7, 1 resimden 1.
    • Gently pull back the foil covering the gold charging port ribbon.
    Hpcom Support Helps HP Printer users to download and install All Hp Printers drivers. We also provide all possible solutions to fix hp Printer problems. If you face any issue in install Hp printer driver or having other problems with the hp Printer, you can follow our 100 % working solutions. In case you can’t able to continue printing, then feel free to contact us. We are happy to serve you.
    hpcom us - Yanıt
  8. HP Slate 7 4601 Charging Port Replacement: adım 8, 2 resimden 1. HP Slate 7 4601 Charging Port Replacement: adım 8, 2 resimden 2.
    • Using the flat end of the spudger, lift up the black panel covering the charging port connector.
    • Gently slide the charging port ribbon out from its housing.
    • It may be easier to use the pointed end of the spudger than your fingers.
  9. HP Slate 7 4601 Charging Port Replacement: adım 9, 1 resimden 1.
    • Lift gold charging strip away from the battery.
  10. HP Slate 7 4601 Charging Port Replacement: adım 10, 2 resimden 1. HP Slate 7 4601 Charging Port Replacement: adım 10, 2 resimden 2.
    • Push the white battery connector out of its housing using the pointed end of the spudger.
  11. HP Slate 7 4601 Charging Port Replacement: adım 11, 1 resimden 1.
    • Using the #00 Phillips Head screwdriver, remove the 5 screws holding the battery in place.
    • The four 1.75mm x 3mm silver Phillips Head screws circled in red are interchangeable.
    • The black 1.75mm x 4mm Phillips Head screw must go back to the same spot during reassembly.
  12. HP Slate 7 4601 Charging Port Replacement: adım 12, 1 resimden 1.
    • Lift battery out of its place and set aside.
  13. HP Slate 7 4601 Charging Port Replacement, Charging Port: adım 13, 2 resimden 1. HP Slate 7 4601 Charging Port Replacement, Charging Port: adım 13, 2 resimden 2.
    • To free the speaker assembly, you will need a #00 Phillips Head screwdriver.
    • Remove the two 1.75mm x 3mm Phillips Head screws from the speaker assembly.
  14. HP Slate 7 4601 Charging Port Replacement: adım 14, 2 resimden 1. HP Slate 7 4601 Charging Port Replacement: adım 14, 2 resimden 2.
    • Pull back the foil overlapping the charging port to reveal another 1.75mm x 3mm Phillips Head screw.
    • Remove the screw with a #00 Phillips Head screwdriver.
  15. HP Slate 7 4601 Charging Port Replacement: adım 15, 1 resimden 1.
    • Lift the charging port and set it aside.
    I need a new charging port were can I buy online
    Saga Vagi - Yanıt
Sonuç
34 farklı kişi bu kılavuzu tamamladı.
Raj Parekh
535 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 13-30, Maness Spring 2014 Cal Poly, Team 13-30, Maness Spring 2014 üyesi
CPSU-MANESS-S14S13G30
3 Üyeler
8 adet Kılavuz yazıldı
15 Yorum
where do you get the replacement parts for charging port
Scott Winstone - Yanıt
Since HP does not supply the replacement ribbon, or many other parts for that matter, it is easiest to search on eBay and/or Craigslist for the parts needed. I found that the UK version of Amazon and eBay offer the best availability for such parts.
Zachary -
I had to stop at Step 1. The T4 Torx screwdriver is too big.
stevwatsn - Yanıt
My apologies for the incorrect sizing of the Torx driver; please use a T3 sized driver, as it is the next size down from the T4.
Zachary -
do you have a product number for the charger strip?
Courtney - Yanıt
I damaged my connector and found the charging strip is available on ebay but is expensive at $50, I managed to find a replacement connector and solder it on for $10 (Ebay Item Number 171379112183). Really happy to have my tablet working again.
William - Yanıt
Thank you so much ifixit.com! Paid an extortionate £24.99 for a replacement cable on Amazon, then used a Torx 4 to do the necessary, following your superb instructions. Worked a treat and my daughter's Slate7 is now charging. Still cheaper than a new tablet (and I hate throwing things away that are all-but working). If it helps anybody, the packet that my replacement came in had the following part numbers: 749770-001 and 729883-001 (these are HP part numbers).
John - Yanıt
In step 13. Why is it necessary to free the speaker assembly?
I don't see what difference this makes.
Motty - Yanıt
Here's a somewhat simpler approach that may work for you as well.
I found, that once I got the back off, the charger seemed to work better. I think, with the back off it gave the frame a little more flexibility, and allowed me to push the USB charger in a little tighter and make better contact. That told me, that the internal mirco USB port and cable were OK, but just not making good contact with my charger.
So, I sealed up the tablet, and using a sharp knife, I shaved a bit of the rubber insulation off the end of my USB charger. That allowed for more of the metal end to stick out and make better contact.
For the moment, it seems to be working, and saves mucking around with the inside of the tablet.
Cheers!
Chris - Yanıt
How do these steps correlate to the hd version of the slate7?
alexanderdutton - Yanıt
Guide was excellent and replaced power strip. Unfortunately device is still dead. Is it worth replacing battery, or should the device work with a dead battery anyway as the power connects direct to the motherboard
gahempton - Yanıt
Mine too, have you found a fix, yet?
Paul Wilkinson -
Instructions very clear, thank you.
I got both the usb harness and a set screw drivers for less than £18. Unit hopfully now fixed.
ournarrowboat - Yanıt
Apart from wrong driver size, which was soon rectified, it's a great tutorial. Thank you for that.
tonyparki - Yanıt
We're can I get a new charging port ribbon cz mine is broken
Saga Vagi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 12
Her zaman: 47,872
