Giriş
This replacement will require caution, when connecting live wires.
Neye ihtiyacın var
Use the plastic opening tool to separate the back cover from the tablet. Carefully use the tool to pry open the sides, going around the entire tablet to lift the sides up.
Once all sides have been pried up, pull the cover off and place it to the side.
Locate the wires connecting the bottom speaker to the motherboard. The wires will be running alongside the battery
Using the PH #000 screw bit, unscrew the two 5.0 mm screws holding the bottom speaker in place
