Giriş
This guide will require caution when connection replacing, due to the strip being easily ripped.
Neye ihtiyacın var
Use the plastic opening tool to separate the back cover from the tablet. Carefully use the tool to pry open the sides, going around the entire tablet to lift the sides up.
Once all sides have been pried up, pull the cover off and place it to the side.
Use the PH #000 phillips head screw driver to remove one 5.0 mm screw.
Move plastic housing and rear facing camera to expose silver bracket.
Bir başkası bu kılavuzu tamamladı.
5 Yorum
Where do you even get the part at??
Where do I even get the part at???
This is completely useless information without a source for the shoddy HP part!
