Ana içeriğe geç
HP Slate 7 Extreme 4400US Rear-Facing Camera Replacement
Neye ihtiyacın var
  1. HP Slate 7 Extreme 4400US Rear-Facing Camera Replacement, Back Cover: adım 1, 3 resimden 1. HP Slate 7 Extreme 4400US Rear-Facing Camera Replacement, Back Cover: adım 1, 3 resimden 2. HP Slate 7 Extreme 4400US Rear-Facing Camera Replacement, Back Cover: adım 1, 3 resimden 3.
    • Use the plastic opening tool to separate the back cover from the tablet. Carefully use the tool to pry open the sides, going around the entire tablet to lift the sides up.
    • Once all sides have been pried up, pull the cover off and place it to the side.
  2. HP Slate 7 Extreme 4400US Rear-Facing Camera Replacement, Rear-Facing Camera: adım 2, 3 resimden 1. HP Slate 7 Extreme 4400US Rear-Facing Camera Replacement, Rear-Facing Camera: adım 2, 3 resimden 2. HP Slate 7 Extreme 4400US Rear-Facing Camera Replacement, Rear-Facing Camera: adım 2, 3 resimden 3.
    • Pull back the tape holding the the camera's connector strip to the device.
    • Use the nylon spudger to flip up the black retaining flap of the zero insertion force (ZIF) connector holding the strip in place.
    • Gently pull the camera's connecting strip out from the port.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Riley Wells
111 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 11-4, Blackwell Fall 2016 USF Tampa, Team 11-4, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S11G4
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 160
