Ana içeriğe geç
HP Slate 7 Extreme 4400US Top Speaker Replacement
Neye ihtiyacın var
  1. HP Slate 7 Extreme 4400US Top Speaker Replacement, Back Cover: adım 1, 3 resimden 1. HP Slate 7 Extreme 4400US Top Speaker Replacement, Back Cover: adım 1, 3 resimden 2. HP Slate 7 Extreme 4400US Top Speaker Replacement, Back Cover: adım 1, 3 resimden 3.
    • Use the plastic opening tool to separate the back cover from the tablet. Carefully use the tool to pry open the sides, going around the entire tablet to lift the sides up.
    • Once all sides have been pried up, pull the cover off and place it to the side.
  2. HP Slate 7 Extreme 4400US Top Speaker Replacement, Top Speaker: adım 2, 2 resimden 1. HP Slate 7 Extreme 4400US Top Speaker Replacement, Top Speaker: adım 2, 2 resimden 2.
    • Use the PH #000 phillips screw bit to remove one 5.0 mm screw.
  3. HP Slate 7 Extreme 4400US Top Speaker Replacement: adım 3, 3 resimden 1. HP Slate 7 Extreme 4400US Top Speaker Replacement: adım 3, 3 resimden 2. HP Slate 7 Extreme 4400US Top Speaker Replacement: adım 3, 3 resimden 3.
    • Gently pull the entire black housing away from device.
    • Locate where the speakers' wires are connected to the motherboard.
    • Using wire cutters, sever the wires connecting the speaker to the motherboard. Strip the wires with a wire stripper and fashion the new wires to the old ones connected to the motherboard to reconnect.
    • You may use a soldering tool to disconnect the wires from the motherboard and to reconnect the new wires back to the motherboard.
Sonuç
Brandon Ko
698 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-4, Blackwell Fall 2016 USF Tampa, Team 11-4, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S11G4
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 145
