Ana içeriğe geç
HP Slate 7 Plus 4200US Tablet Cover Replacement
Neye ihtiyacın var
  1. HP Slate 7 Plus 4200US Tablet Cover Replacement, Tablet Cover: adım 1, 1 resimden 1.
    • Turn off the tablet and disconnect the power and all external devices from the tablet.
    • Position the tablet with the display panel down and the right side toward you.
    • Carefully insert a plastic opening tool between the tablet cover and display panel assembly, separating the two components. The first insertion point should be between the power button and the volume buttons.
  2. HP Slate 7 Plus 4200US Tablet Cover Replacement: adım 2, 2 resimden 1. HP Slate 7 Plus 4200US Tablet Cover Replacement: adım 2, 2 resimden 2.
    • Slide the tool around the perimeter of the tablet until the edge of the cover is completely separated from the display panel assembly.
  3. HP Slate 7 Plus 4200US Tablet Cover Replacement: adım 3, 3 resimden 1. HP Slate 7 Plus 4200US Tablet Cover Replacement: adım 3, 3 resimden 2. HP Slate 7 Plus 4200US Tablet Cover Replacement: adım 3, 3 resimden 3.
    • Pry open the back cover to take it off.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jessica Andrade
860 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-1, Sullivan Fall 2016 USF Tampa, Team 3-1, Sullivan Fall 2016 üyesi
USFT-SULLIVAN-F16S3G1
3 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 306
