Ana içeriğe geç
HP Slate 8 Pro Battery Replacement
Neye ihtiyacın var
    1. HP Slate 8 Pro Battery Replacement, Remove Back Panel: adım 1, 2 resimden 1. HP Slate 8 Pro Battery Replacement, Remove Back Panel: adım 1, 2 resimden 2.
      • Secure the suction cup to the center of the device’s screen.
      • Begin to pull upwards with the suction cup. While pulling, start easing the plastic opening tool into the space between the screen and the device. This will gradually separate the screen from the plastic back panel.
      FixBot'a Sor
      Yorum Ekle
    2. HP Slate 8 Pro Battery Replacement, Remove yellow cables: adım 2, 2 resimden 1. HP Slate 8 Pro Battery Replacement, Remove yellow cables: adım 2, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Use a spudger tool to release the black clips on the two connectors holding the flat, yellow cable in place.
      • Use the tweezers to pull the flat, yellow cable out of its connectors.
      • Use the tweezers to disconnect the battery connector from the circuit board.
      • Using the spudger tool again, pry up and release the connectors at the ends of the flat, orange cable.
      • Remove the flat, orange cable.
      FixBot'a Sor
      Yorum Ekle
    3. HP Slate 8 Pro Battery Replacement, Remove Screws Around Battery: adım 3, 1 resimden 1.
      • As shown, the battery is held in place by a total of 8 screws. Use the #00 Phillips screwdriver to remove all 8.
      FixBot'a Sor
      Yorum Ekle
    4. HP Slate 8 Pro Battery Replacement, Lift Battery out of Device: adım 4, 1 resimden 1.
      • Grasp the battery and remove it from the device.
      • Do not attempt to open or tamper with the battery. This could result in injury.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jose Revelo
311 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-4, Blackwell Fall 2014 USF Tampa, Team 9-4, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S9G4
4 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
Nahi hua hai
Md Mozahid - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 33
Her zaman: 3,717
