Ana içeriğe geç
HP Slate 8 Pro IO Board Replacement
Neye ihtiyacın var
  1. HP Slate 8 Pro IO Board Replacement, Remove back cover: adım 1, 1 resimden 1.
    • Turn off the tablet. If you are unsure whether the tablet is off or in Hibernation, turn the tablet on, and then shut it down
    • Remove the back cover.
  2. HP Slate 8 Pro IO Board Replacement, Disconnect battery cable: adım 2, 1 resimden 1.
    • Disconnect the battery cable from the system board
  3. HP Slate 8 Pro IO Board Replacement, Remove ribbon cables: adım 3, 1 resimden 1.
    • Pull the yellow ribbons
  4. HP Slate 8 Pro IO Board Replacement, Disconnect speaker cables: adım 4, 1 resimden 1.
    • Disconnect the speaker cables from the I/O board
  5. HP Slate 8 Pro IO Board Replacement, Remove screws: adım 5, 1 resimden 1.
    • Remove the two Phillips PM1.5×4.0 screws that secure the I/O board to the display panel assembly.
  6. HP Slate 8 Pro IO Board Replacement, Remove the IO board: adım 6, 1 resimden 1.
    • Remove the IO board carefully.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Claudia
246 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-4, Blackwell Fall 2014 USF Tampa, Team 9-4, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S9G4
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 808
