Ana içeriğe geç
HP Slate 8 Pro Microphone Replacement
Neye ihtiyacın var
  1. HP Slate 8 Pro Microphone Replacement, Remove the back cover: adım 1, 1 resimden 1.
    • Before opening your device, turn off the tablet. If you are unsure whether the tablet is off or in Hibernation, turn the tablet on, and then shut it down through the operating system.
    • Unplug your tablet from any power supply
    • Remove all external devices.
    • Remove back cover with plastic tools to avoid scratching the screen.
  2. HP Slate 8 Pro Microphone Replacement, Remove screws: adım 2, 1 resimden 1.
    • Remove all screws from the sides of the battery
  3. HP Slate 8 Pro Microphone Replacement, Disconnect the battery cable: adım 3, 1 resimden 1.
    • Disconnect the battery cable from the system board.
    • Use a little bit of pressure to remove the cable.
  4. HP Slate 8 Pro Microphone Replacement, Remove ZIF connector: adım 4, 1 resimden 1.
    • Release the ZIF connector to which the microphone cable is attached
  5. HP Slate 8 Pro Microphone Replacement, Remove the  microphone: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove microphone from panel using tweezers
    • Add your new microphone
Sonuç
Claudia
252 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-4, Blackwell Fall 2014 USF Tampa, Team 9-4, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S9G4
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 515
