Ana içeriğe geç
HP Slate 8 Pro Speakers Replacement
Neye ihtiyacın var
  1. HP Slate 8 Pro Speakers Replacement, Remove back cover: adım 1, 1 resimden 1.
    • Use plastic opening tool to pry back panel off.
  2. HP Slate 8 Pro Speakers Replacement, Detach IO Board from system: adım 2, 2 resimden 1. HP Slate 8 Pro Speakers Replacement, Detach IO Board from system: adım 2, 2 resimden 2.
    • Remove the orange and yellow ribbon cables.
    • detach the screws along the IO board
  3. HP Slate 8 Pro Speakers Replacement, Remove the IO board and the speakers: adım 3, 1 resimden 1.
    • Remove the IO board and the speakers circuit. Note that they are held together.
  4. HP Slate 8 Pro Speakers Replacement, Detach the speakers from the IO board.: adım 4, 1 resimden 1.
    • The tablet has two speakers. Each speaker is located to both sides of the IO board.
    • Detach the speakers from the cables that connect the speakers and the IO board. You will find more details in step 5 and 6.
  5. HP Slate 8 Pro Speakers Replacement, Remove the wires of the speakers from the IO board.: adım 5, 1 resimden 1.
    • To remove the cables that connect the speakers and the IO board, apply a subtle pressure to pull the cable out.
  6. HP Slate 8 Pro Speakers Replacement, Replace your speakers with the new parts: adım 6, 2 resimden 1. HP Slate 8 Pro Speakers Replacement, Replace your speakers with the new parts: adım 6, 2 resimden 2.
    • Once you detach the speakers from the IO board, you should have three pieces as shown.
    • You are ready to replace the speakers.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jose Revelo
305 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-4, Blackwell Fall 2014 USF Tampa, Team 9-4, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S9G4
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 431
