Ana içeriğe geç
HP Spectre 13-4002dx Display Replacement
Neye ihtiyacın var
  1. HP Spectre 13-4002dx Display Replacement, Motherboard: adım 1, 3 resimden 1. HP Spectre 13-4002dx Display Replacement, Motherboard: adım 1, 3 resimden 2. HP Spectre 13-4002dx Display Replacement, Motherboard: adım 1, 3 resimden 3.
    • Remove the black tape from the motherboard.
    • Remove five screws using the Phillips #00 screwdriver that holds the motherboard in place.
    • Disconnect five ribbon cables, three power cables, and two wifi antennas from the motherboard.
    • Gently lift the motherboard out of the computer. Be careful to not to disturb the CPU fan.
    • Do not bend the motherboard.
  2. HP Spectre 13-4002dx Display Replacement, Display: adım 2, 1 resimden 1.
    • Remove four screws connecting the screen to the laptop case with the Phillips #00 screwdriver.
  3. HP Spectre 13-4002dx Display Replacement: adım 3, 2 resimden 1. HP Spectre 13-4002dx Display Replacement: adım 3, 2 resimden 2.
    • Bring the laptop screen to a 270 degree angle from the base.
    • Pull the display towards you for the display to pop out of the base.
    • Gently remove the display to ensure that the cables do not get caught on the case.
  4. HP Spectre 13-4002dx Display Replacement: adım 4, 2 resimden 1. HP Spectre 13-4002dx Display Replacement: adım 4, 2 resimden 2.
    • Remove the rubber seal around display with the opening tool.
    • Pry the display off.
    • Be careful while removing the display as it could snap and cause damage and/or injury. Be careful to not cut any wiring between the screen and its casing.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 15
Her zaman: 449
