Giriş
This guide is for the removal and replacement the display on the HP Spectre 13-4002dx if your current display is malfunctioning or broken. Be wary of broken glass from the display and be sure to not accidentally cut any wires during the process.
Neye ihtiyacın var
Remove the black tape from the motherboard.
Remove five screws using the Phillips #00 screwdriver that holds the motherboard in place.
Disconnect five ribbon cables, three power cables, and two wifi antennas from the motherboard.
Gently lift the motherboard out of the computer. Be careful to not to disturb the CPU fan.
Remove four screws connecting the screen to the laptop case with the Phillips #00 screwdriver.
