Ana içeriğe geç
HP Spectre 13-4002dx Heat Sink Replacement
Neye ihtiyacın var
  1. HP Spectre 13-4002dx Heat Sink Replacement, Bottom Case: adım 1, 2 resimden 1. HP Spectre 13-4002dx Heat Sink Replacement, Bottom Case: adım 1, 2 resimden 2.
    • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
  2. HP Spectre 13-4002dx Heat Sink Replacement: adım 2, 2 resimden 1. HP Spectre 13-4002dx Heat Sink Replacement: adım 2, 2 resimden 2.
    • Pry up one corner of the bottom case with a spudger.
    • Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Remove the bottom case.
  3. HP Spectre 13-4002dx Heat Sink Replacement, Heat Sink: adım 3, 3 resimden 1. HP Spectre 13-4002dx Heat Sink Replacement, Heat Sink: adım 3, 3 resimden 2. HP Spectre 13-4002dx Heat Sink Replacement, Heat Sink: adım 3, 3 resimden 3.
    • Remove the tape outlined in red.
    • The tape can tear easily.
  4. HP Spectre 13-4002dx Heat Sink Replacement: adım 4, 2 resimden 1. HP Spectre 13-4002dx Heat Sink Replacement: adım 4, 2 resimden 2.
    • Remove the four 3 mm screws using a Phillips #0 screwdriver.
  5. HP Spectre 13-4002dx Heat Sink Replacement: adım 5, 1 resimden 1.
    • Remove the heat sink from the laptop.
Sonuç
Cayce Stewart
725 İtibar
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 263
