Giriş
The motherboard is the central hub for communication between all of the components in a device. If one or more components start to fail, your motherboard may need to be replaced. Use this guide to replace the motherboard in your laptop.
Neye ihtiyacın var
Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
Orient the laptop the same way as the pictures. The battery is bordered in a red outline.
Remove the six 4 mm screws using a Phillips #000 screwdriver.
Remove the black tape from the motherboard.
Remove five screws using the Phillips #00 screwdriver that holds the motherboard in place.
Disconnect five ribbon cables, three power cables, and two wifi antennas from the motherboard.
Gently lift the motherboard out of the computer. Be careful to not to disturb the CPU fan.
