Ana içeriğe geç
HP Spectre 13-4002dx Speakers Replacement
Neye ihtiyacın var
  1. HP Spectre 13-4002dx Speakers Replacement, Bottom Case: adım 1, 2 resimden 1. HP Spectre 13-4002dx Speakers Replacement, Bottom Case: adım 1, 2 resimden 2.
    • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
  2. HP Spectre 13-4002dx Speakers Replacement: adım 2, 2 resimden 1. HP Spectre 13-4002dx Speakers Replacement: adım 2, 2 resimden 2.
    • Pry up one corner of the bottom case with a spudger.
    • Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Remove the bottom case.
  3. HP Spectre 13-4002dx Speakers Replacement, Battery: adım 3, 3 resimden 1. HP Spectre 13-4002dx Speakers Replacement, Battery: adım 3, 3 resimden 2. HP Spectre 13-4002dx Speakers Replacement, Battery: adım 3, 3 resimden 3.
    • Orient the laptop the same way as the pictures. The battery is bordered in a red outline.
    • Remove the six 4 mm screws using a Phillips #000 screwdriver.
  4. HP Spectre 13-4002dx Speakers Replacement: adım 4, 3 resimden 1. HP Spectre 13-4002dx Speakers Replacement: adım 4, 3 resimden 2. HP Spectre 13-4002dx Speakers Replacement: adım 4, 3 resimden 3.
    • Do not disconnect the cable connector shown in the red box.
    • The speaker cable may be attached to the battery with black electrical tape. If so, remove the tape.
    • Move the cable clear of the battery.
  5. HP Spectre 13-4002dx Speakers Replacement: adım 5, 2 resimden 1. HP Spectre 13-4002dx Speakers Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Do not disconnect the cable connector located in the red box.
    • Use tweezers to remove the speaker cable from the groove attached to the battery.
    • Push the cable to the side so it does not get in the way of the battery removal.
  6. HP Spectre 13-4002dx Speakers Replacement: adım 6, 3 resimden 1. HP Spectre 13-4002dx Speakers Replacement: adım 6, 3 resimden 2. HP Spectre 13-4002dx Speakers Replacement: adım 6, 3 resimden 3.
    • Disconnect the battery cable connector by sliding it out of the socket.
    • Move the battery out of the way if you need more room to disconnect the power cable.
  7. HP Spectre 13-4002dx Speakers Replacement: adım 7, 1 resimden 1.
    • Carefully remove the battery.
  8. HP Spectre 13-4002dx Speakers Replacement, Speakers: adım 8, 3 resimden 1. HP Spectre 13-4002dx Speakers Replacement, Speakers: adım 8, 3 resimden 2. HP Spectre 13-4002dx Speakers Replacement, Speakers: adım 8, 3 resimden 3.
    • Remove four screws located on the bottom corners of speaker covers using the Phillips #00 screwdrivers.
    • Disconnect both 3-pin cables located on the edge of the computer.
    • Remove both speakers.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 185
