Ana içeriğe geç
HP Spectre 13-4002dx Vent Fan Replacement
Neye ihtiyacın var
  1. HP Spectre 13-4002dx Vent Fan Replacement, Bottom Case: adım 1, 2 resimden 1. HP Spectre 13-4002dx Vent Fan Replacement, Bottom Case: adım 1, 2 resimden 2.
    • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
  2. HP Spectre 13-4002dx Vent Fan Replacement: adım 2, 2 resimden 1. HP Spectre 13-4002dx Vent Fan Replacement: adım 2, 2 resimden 2.
    • Pry up one corner of the bottom case with a spudger.
    • Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Remove the bottom case.
  3. HP Spectre 13-4002dx Vent Fan Replacement, Vent Fan: adım 3, 3 resimden 1. HP Spectre 13-4002dx Vent Fan Replacement, Vent Fan: adım 3, 3 resimden 2. HP Spectre 13-4002dx Vent Fan Replacement, Vent Fan: adım 3, 3 resimden 3.
    • Remove the strip of black electrical tape.
    • Pull the tape away from the vent fan.
    • Pull gently, as the tape is easy to rip.
  4. HP Spectre 13-4002dx Vent Fan Replacement: adım 4, 2 resimden 1. HP Spectre 13-4002dx Vent Fan Replacement: adım 4, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the two 40 mm screws securing the fan assembly to the motherboard.
  5. HP Spectre 13-4002dx Vent Fan Replacement: adım 5, 3 resimden 1. HP Spectre 13-4002dx Vent Fan Replacement: adım 5, 3 resimden 2. HP Spectre 13-4002dx Vent Fan Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, disconnect the wire connection between the laptop and the vent fan.
  6. HP Spectre 13-4002dx Vent Fan Replacement: adım 6, 1 resimden 1.
    • Remove the vent fan.
Sonuç
Cayce Stewart
725 İtibar
6 adet Kılavuz yazıldı
Bir Yorum
Any idea what model# the fan is?
ayekay - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 283
