Ana içeriğe geç
HP Spectre Pro X360 G1 Battery Replacement
Neye ihtiyacın var
  1. HP Spectre Pro X360 G1 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off and unplug the laptop.
    • Flip the laptop so that the backplate is exposed.
  2. HP Spectre Pro X360 G1 Battery Replacement: adım 2, 1 resimden 1.
    • Remove the eight screws with the T5 Torx screwdriver.
  3. HP Spectre Pro X360 G1 Battery Replacement: adım 3, 1 resimden 1.
    • Using the plastic opening tools carefully lift the backplate.
  4. HP Spectre Pro X360 G1 Battery Replacement: adım 4, 1 resimden 1.
    • Remove the 4 screws holding down the battery with the Phillips #1 screwdriver.
  5. HP Spectre Pro X360 G1 Battery Replacement: adım 5, 2 resimden 1. HP Spectre Pro X360 G1 Battery Replacement: adım 5, 2 resimden 2.
    • Disconnect the 3 wires connected to the battery.
    • Tweezers may be needed to disconnect the wires.
  6. HP Spectre Pro X360 G1 Battery Replacement: adım 6, 1 resimden 1.
    • Lift the battery off of the alignment pins on the top cover and remove it from the device.
Sonuç
Alexis Garcia
183 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 19
Her zaman: 1,492
