Ana içeriğe geç
HP Spectre x2 12-a002dx Screen Replacement
Neye ihtiyacın var
    1. HP Spectre x2 12-a002dx Screen Replacement, Screen: adım 1, 1 resimden 1.
      • Make sure the device is powered off and the kick stand is retracted.
      • The HP Spectre should be placed on a flat surface with the keyboard detached.
      FixBot'a Sor
      Yorum Ekle
    2. HP Spectre x2 12-a002dx Screen Replacement: adım 2, 3 resimden 1. HP Spectre x2 12-a002dx Screen Replacement: adım 2, 3 resimden 2. HP Spectre x2 12-a002dx Screen Replacement: adım 2, 3 resimden 3.
      Bu adımda kullanılan alet:
      • To remove the screen, there is an entire system of clips which need to be undone as well as 4 Phillips M1.5x2.7 screws.
      • The screws should be removed using a Phillips #000 screwdriver. There is a sticker where the laptop attaches to the keyboard.
      • Heat the sticker (if needed) and use fine point tweezers to grip the sticker and remove it.
      FixBot'a Sor
      Yorum Ekle
    3. HP Spectre x2 12-a002dx Screen Replacement: adım 3, 3 resimden 1. HP Spectre x2 12-a002dx Screen Replacement: adım 3, 3 resimden 2. HP Spectre x2 12-a002dx Screen Replacement: adım 3, 3 resimden 3.
      • Use the plastic opening tools or insert a spudger to begin unclipping the system.
      • Pry the screen off once all the clips have been unclipped.
      • The screen may shatter if not already shattered (beware of flying glass).
      FixBot'a Sor
      Yorum Ekle
      • This screen will break. There is double tape underneath the frame, which is not listed in here.
      FixBot'a Sor
      Yorum Ekle
    4. HP Spectre x2 12-a002dx Screen Replacement: adım 5, 3 resimden 1. HP Spectre x2 12-a002dx Screen Replacement: adım 5, 3 resimden 2. HP Spectre x2 12-a002dx Screen Replacement: adım 5, 3 resimden 3.
      • Remove the connecting cable of the screen and battery. Use a spudger to reveal the adhesive strip and carefully peel it off.
      • Insert a spudger to the other end and release the ZIF connectors. Detach the cable.
      • While a metal spudger is pictured, use a black nylon spudger instead because it is ESD safe.
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Talha Bin Amir
684 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S10-G6, Thompson Fall 2017 USF Tampa, Team S10-G6, Thompson Fall 2017 üyesi
USFT-THOMPSON-F17S10G6
4 Üyeler
50 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 38
Her zaman: 5,270
