Ana içeriğe geç
HP Spectre x360 13-ac023dx Fan Replacement
Neye ihtiyacın var
  1. HP Spectre x360 13-ac023dx Fan  Replacement, Battery: adım 1, 2 resimden 1. HP Spectre x360 13-ac023dx Fan  Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the laptop over so the model sticker faces the ceiling.
  2. HP Spectre x360 13-ac023dx Fan  Replacement: adım 2, 3 resimden 1. HP Spectre x360 13-ac023dx Fan  Replacement: adım 2, 3 resimden 2. HP Spectre x360 13-ac023dx Fan  Replacement: adım 2, 3 resimden 3.
    • Use a Torx #5 screwdriver to remove the six 3.5 mm screws holding the back cover to the laptop.
  3. HP Spectre x360 13-ac023dx Fan  Replacement: adım 3, 2 resimden 1. HP Spectre x360 13-ac023dx Fan  Replacement: adım 3, 2 resimden 2.
    • Use the Phillips #000 screwdriver to remove the four 3.5 mm screws holding the battery.
    • After removing the screws, detach the battery wire from the mother board with the iFixit opening tool.
    • Then, carefully lift the battery off with the iFixit opening tool.
  4. HP Spectre x360 13-ac023dx Fan  Replacement, Fan: adım 4, 1 resimden 1.
    • Locate the Cooling Fan in the device.
  5. HP Spectre x360 13-ac023dx Fan  Replacement: adım 5, 2 resimden 1. HP Spectre x360 13-ac023dx Fan  Replacement: adım 5, 2 resimden 2.
    • Use the Phillips #000 screwdriver to remove the 3mm screws holding the fan in place.
    • Remove the wires connecting to the motherboard, using the iFixit opening tool.
    • The iFixit Opening Tool is not required, but recommended
  6. HP Spectre x360 13-ac023dx Fan  Replacement: adım 6, 1 resimden 1.
    • Remove the Cooling Fan.
Sonuç
Jonathan
498 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G6, Botvin Fall 2019 UMass Dartmouth, Team S1-G6, Botvin Fall 2019 üyesi
UMASSD-BOTVIN-F19S1G6
3 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 41
Her zaman: 5,001
