Ana içeriğe geç
HP Spectre x360 13-ac023dx Motherboard Replacement
Neye ihtiyacın var
  1. HP Spectre x360 13-ac023dx Motherboard Replacement, Battery: adım 1, 2 resimden 1. HP Spectre x360 13-ac023dx Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the laptop over so the model sticker faces the ceiling.
  2. HP Spectre x360 13-ac023dx Motherboard Replacement: adım 2, 3 resimden 1. HP Spectre x360 13-ac023dx Motherboard Replacement: adım 2, 3 resimden 2. HP Spectre x360 13-ac023dx Motherboard Replacement: adım 2, 3 resimden 3.
    • Use a Torx #5 screwdriver to remove the six 3.5 mm screws holding the back cover to the laptop.
  3. HP Spectre x360 13-ac023dx Motherboard Replacement: adım 3, 2 resimden 1. HP Spectre x360 13-ac023dx Motherboard Replacement: adım 3, 2 resimden 2.
    • Use the Phillips #000 screwdriver to remove the four 3.5 mm screws holding the battery.
    • After removing the screws, detach the battery wire from the mother board with the iFixit opening tool.
    • Then, carefully lift the battery off with the iFixit opening tool.
  4. HP Spectre x360 13-ac023dx Motherboard Replacement, Fan: adım 4, 1 resimden 1.
    • Locate the Cooling Fan in the device.
  5. HP Spectre x360 13-ac023dx Motherboard Replacement: adım 5, 2 resimden 1. HP Spectre x360 13-ac023dx Motherboard Replacement: adım 5, 2 resimden 2.
    • Use the Phillips #000 screwdriver to remove the 3mm screws holding the fan in place.
    • Remove the wires connecting to the motherboard, using the iFixit opening tool.
    • The iFixit Opening Tool is not required, but recommended
  6. HP Spectre x360 13-ac023dx Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove the Cooling Fan.
  7. HP Spectre x360 13-ac023dx Motherboard Replacement, WiFi Card: adım 7, 1 resimden 1.
    • Locate the WiFi card in the top left of the motherboard.
  8. HP Spectre x360 13-ac023dx Motherboard Replacement: adım 8, 1 resimden 1.
    • Use the Phillips #000 screwdriver to remove the screw holding the wifi card in place.
  9. HP Spectre x360 13-ac023dx Motherboard Replacement: adım 9, 2 resimden 1. HP Spectre x360 13-ac023dx Motherboard Replacement: adım 9, 2 resimden 2.
    • Once the screw is removed, hold the WiFi card by it's sides and raise it up whiling sliding it out from the slot.
  10. HP Spectre x360 13-ac023dx Motherboard Replacement: adım 10, 1 resimden 1.
    • After removing the Wifi card, place the card within a static dissipative bag.
  11. HP Spectre x360 13-ac023dx Motherboard Replacement: adım 11, 1 resimden 1.
    • Hold the replacement Wifi card by the edges and remove it out of the static-dissipative bag.
  12. HP Spectre x360 13-ac023dx Motherboard Replacement: adım 12, 1 resimden 1.
    • Align the notches on the Wifi card with the keys on the Wifi card slot.
    • Hold the card by the edges and slide the Wifi card into the Wifi Card slot.
  13. HP Spectre x360 13-ac023dx Motherboard Replacement: adım 13, 1 resimden 1.
    • Use the Phillips #000 screwdriver to attach the screw holding the Wifi card in place.
  14. HP Spectre x360 13-ac023dx Motherboard Replacement, Motherboard: adım 14, 1 resimden 1.
    • Ensure that all other components which were previously removed are not longer attached.
  15. HP Spectre x360 13-ac023dx Motherboard Replacement: adım 15, 3 resimden 1. HP Spectre x360 13-ac023dx Motherboard Replacement: adım 15, 3 resimden 2. HP Spectre x360 13-ac023dx Motherboard Replacement: adım 15, 3 resimden 3.
    • Disconnect the wires which connect the motherboard to the rest of the components.
    • The black and red wire can be removed by pulling the wire upwards.
  16. HP Spectre x360 13-ac023dx Motherboard Replacement: adım 16, 3 resimden 1. HP Spectre x360 13-ac023dx Motherboard Replacement: adım 16, 3 resimden 2. HP Spectre x360 13-ac023dx Motherboard Replacement: adım 16, 3 resimden 3.
    • Use the Phillips #000 screwdriver to remove the three 3.5 mm screws which keep the motherboard in place.
  17. HP Spectre x360 13-ac023dx Motherboard Replacement: adım 17, 2 resimden 1. HP Spectre x360 13-ac023dx Motherboard Replacement: adım 17, 2 resimden 2.
    • Carefully lift and remove the motherboard.
Sonuç
Jonathan
498 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G6, Botvin Fall 2019 UMass Dartmouth, Team S1-G6, Botvin Fall 2019 üyesi
UMASSD-BOTVIN-F19S1G6
3 Üyeler
11 adet Kılavuz yazıldı
Bir Yorum
Can I get ho spectre x360 motherboard to buy from your end?
Immanuel - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 52
Her zaman: 3,829
