Ana içeriğe geç
HP Spectre x360 13-aw0xxx Battery Replacement
Neye ihtiyacın var
  1. HP Spectre x360 13-aw0xxx Battery Replacement, Lower Case: adım 1, 2 resimden 1. HP Spectre x360 13-aw0xxx Battery Replacement, Lower Case: adım 1, 2 resimden 2.
    • Remove the following screws securing the lower case:
    • Four Phillips #00 6 mm screws
    • Two T5 Torx 3 mm screws
  2. HP Spectre x360 13-aw0xxx Battery Replacement: adım 2, 1 resimden 1.
    • Insert an opening tool in the seam between the lower case and chassis.
    • Pry around the perimeter until the lower case fully releases.
    • Remove the lower case.
  3. HP Spectre x360 13-aw0xxx Battery Replacement, Battery: adım 3, 2 resimden 1. HP Spectre x360 13-aw0xxx Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Use two opening tools, one on either side of the battery plug, to slowly pull the plug straight out of its port.
    • Alternatively, use your fingernails.
  4. HP Spectre x360 13-aw0xxx Battery Replacement: adım 4, 2 resimden 1. HP Spectre x360 13-aw0xxx Battery Replacement: adım 4, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the six 2.5 mm screws securing the battery.
  5. HP Spectre x360 13-aw0xxx Battery Replacement: adım 5, 2 resimden 1. HP Spectre x360 13-aw0xxx Battery Replacement: adım 5, 2 resimden 2.
    • Carefully lift the edge of the battery with an opening tool.
    • Lift the battery up and out.
Sonuç
Thomas Hayslett
97 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 24
Son 30 gün: 169
Her zaman: 1,557
