Giriş
This guide will instruct you on how to remove and replace the battery. Battery replacement may be necessary if the battery is not able to hold a charge.
Neye ihtiyacın var
Turn off and unplug the laptop.
Flip over the laptop so that the bottom backplate is exposed.
Bu adımda kullanılan alet:Tweezers$4.99
With the backplate removed, remove the four 3 mm screws securing the battery with a Phillips #1 screwdriver.
With the screws removed, disconnect the 3 wires connected to the battery.
4 farklı kişi bu kılavuzu tamamladı.
