Ana içeriğe geç
HP Spectre x360 13t-4000 Wifi Adapter Replacement
Neye ihtiyacın var
  1. HP Spectre x360 13t-4000 Wifi Adapter Replacement, Bottom Cover: adım 1, 2 resimden 1. HP Spectre x360 13t-4000 Wifi Adapter Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Turn off and unplug the laptop.
    • Flip over the laptop so that the bottom backplate is exposed.
  2. HP Spectre x360 13t-4000 Wifi Adapter Replacement: adım 2, 2 resimden 1. HP Spectre x360 13t-4000 Wifi Adapter Replacement: adım 2, 2 resimden 2.
    • Use a T5 screwdriver to remove the six 3 mm screws that secure the backplate.
    • Use the same screwdriver to remove the two 7 mm screws.
  3. HP Spectre x360 13t-4000 Wifi Adapter Replacement: adım 3, 3 resimden 1. HP Spectre x360 13t-4000 Wifi Adapter Replacement: adım 3, 3 resimden 2. HP Spectre x360 13t-4000 Wifi Adapter Replacement: adım 3, 3 resimden 3.
    • Insert an opening tool under the bottom cover at the screen hinges, and gently pry the cover free.
    • Carefully work your way around the cover's edges to pop it off completely.
  4. HP Spectre x360 13t-4000 Wifi Adapter Replacement, Battery: adım 4, 3 resimden 1. HP Spectre x360 13t-4000 Wifi Adapter Replacement, Battery: adım 4, 3 resimden 2. HP Spectre x360 13t-4000 Wifi Adapter Replacement, Battery: adım 4, 3 resimden 3.
    • With the backplate removed, remove the four 3 mm screws securing the battery with a Phillips #1 screwdriver.
    • With the screws removed, disconnect the 3 wires connected to the battery.
    • Tweezers may be needed to remove the wires.
  5. HP Spectre x360 13t-4000 Wifi Adapter Replacement, Wifi Adapter: adım 5, 3 resimden 1. HP Spectre x360 13t-4000 Wifi Adapter Replacement, Wifi Adapter: adım 5, 3 resimden 2. HP Spectre x360 13t-4000 Wifi Adapter Replacement, Wifi Adapter: adım 5, 3 resimden 3.
    • Using a Phillips#0 screwdriver, remove the 2 mm screw.
    • Located to the right of the screw, there are two wires connected to the adapter. Using tweezers, carefully remove the wires.
    • There may be tape covering the wires.
    • Now you can remove the adapter by pulling it from its socket.
Sonuç
Brandon Carvalho
566 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G4, Simcock Spring 2019 UMass Dartmouth, Team S2-G4, Simcock Spring 2019 üyesi
UMASSD-SIMCOCK-S19S2G4
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 907
