Ana içeriğe geç
HP Spectre x360 15-bl012dx Battery Replacement
Neye ihtiyacın var
  1. HP Spectre x360 15-bl012dx Battery Replacement, Battery Replacement: adım 1, 2 resimden 1. HP Spectre x360 15-bl012dx Battery Replacement, Battery Replacement: adım 1, 2 resimden 2.
    • Power off the device before beginning disassembly.
    • Place the computer so that the back panel is facing up. Begin by removing the two visible Torx T5 9 mm screws near the hinges.
    • Next, remove the four visible Torx T5 3 mm on the sides.
    • Keep track of all screws.
  2. HP Spectre x360 15-bl012dx Battery Replacement: adım 2, 3 resimden 1. HP Spectre x360 15-bl012dx Battery Replacement: adım 2, 3 resimden 2. HP Spectre x360 15-bl012dx Battery Replacement: adım 2, 3 resimden 3.
    • Please note the upper two feet are already removed. The device was given to us this way.
    • Remove the two upper feet using an opening tool or spudger if they are still in place. The upper feet are closer to the hinges for the screen.
    • Remove the two 8 mm Phillips #1 screws under the feet.
    • These are the final screws to remove from the back panel. In total, you should remove eight screws between Steps 1 and 2.
  3. HP Spectre x360 15-bl012dx Battery Replacement: adım 3, 1 resimden 1.
    • Use a spudger to pry the back panel off of the laptop. Work your way around the perimeter of the device to loosen the connection.
    • Take the back panel off of the laptop.
  4. HP Spectre x360 15-bl012dx Battery Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove six 4 mm screws securing the battery.
  5. HP Spectre x360 15-bl012dx Battery Replacement: adım 5, 3 resimden 1. HP Spectre x360 15-bl012dx Battery Replacement: adım 5, 3 resimden 2. HP Spectre x360 15-bl012dx Battery Replacement: adım 5, 3 resimden 3.
    • Unplug the battery connector located on the motherboard.
    • Remove the battery from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Peyton Stewart
282 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 1-1, Hunter Spring 2022 Clemson, Team 1-1, Hunter Spring 2022 üyesi
CLEM-HUNTER-S22S1G1
5 Üyeler
5 adet Kılavuz yazıldı
5 Yorum
Great writeup. Any idea where I could get an OEM or OEM-quality replacement battery?
Ben - Yanıt
Excellent guidance, many thanks!
Brenda Mallinson - Yanıt
Thanks for the guide! Figured there were screws under the rear feet but this confirmed it and prevented me from doing something silly.
Nick Di Vona - Yanıt
Where are you guys finding replacement batteries from? I don't want to go through the process of buying and returning crappy batteries
Kisan Patel - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 50
Her zaman: 3,439
